TwinTurbo.NET: Nissan 300ZX forum - Re: The manifold gauges should give you an idea...
Compiratenew
on June 06, 2017 at 12:27 PM
posted by Jehannum
on June 06, 2017 at 11:00 AM
So I guess when they say 1.87-2.09lb for an na, 1.65-1.87lb for tt and 5.3 total oz oil, then they're really saying whatever's close? They manual seems to be pretty adamant about measuring. The oil part is very important.
Does an AC recharge require a vacuum?
Stokens (AR)
18:32:11 06/05/17
Re: Does an AC recharge require a vacuum?
Compiratenew
18:55:05 06/05/17
Jehannum
11:00:00 06/06/17
Re: The manifold gauges should give you an idea... -
Compiratenew
12:27:09 06/06/17
The Gauges will give you an Idea of How Low it is
Cjw3
15:17:13 06/06/17
Only if there is less then about 5 PSI when you start (n/m)
Cjw3
22:38:23 06/05/17
No
emnm187
05:21:11 06/06/17
Re: No
Compiratenew
12:28:30 06/06/17
Yup! and if it sat awhile the system has to be vacuumed>>
ZUL8TR
13:18:17 06/06/17
Vacuum is to remove air and moisture
emnm187
07:41:44 06/08/17
Re: Vacuum is to remove air and moisture
Compiratenew
19:21:56 06/08/17
It was Made and assembled on Wed. In my 1992 Z >>
ZUL8TR
04:54:21 06/11/17
